You can see the archived poll results on the Wayback Machine:
https://web.archive.org/web/20221220093741/https://budgetlightforum.com/t/-/72690
im looking to do one of the above flashlights to make copper heatsink if interested please post your vote/any ideas
Really I think your 2+ is it because of the Ti light finishing up now. also how many other lights would this pill fit?
Also we will need the extra deep version for TIR installs!!!
I was thinking the UF-1504 would be a killer since a GB just ended as for that pill^^^ im not sure how many they will fit
EDIT: If there is a light u would like added to the poll please post ill add it to see if any interest
UF-1405? Or is the UF-1405 and UF-1504 the same except the UF-1405 needs more room for a buck driver? Or are the pills totally different animals thread wise?
There are so many p60’s around it would be nice to see a copper pill that fits without a spring.
1505
I voted for the C8 because I’ve been dying to put a MT-G2 or XHP in one but have been worried about the heat.
S2+… hopefully they are all more-or-less the same and the pills fit.
One reason I wouldn’t vote p60 is the host cavities are all over the map.
Hi, im in for Convoy c8.
What is convoy c8 new version 2¿? The last don´t have pill any information ?
Thanks.
im going to ask the machine guy if we can do 25pcs of each
Convoy c8,convoy s+ may be a run for the eagle eye x6 ?
“One reason I wouldn’t vote p60 is the host cavities are all over the map.”
Yes but there are so many that you could do separate runs of 501/502’s and L2’s.
Are you making a triple? If so, I’d vote s2+
Yes thats what ill be making mine, it will be a threaded copper or even aluminum ? slug with a center hole for the wire and have the bottom to where you can put your driver
Is it going to be a spacer or pill replacement? Will you consider S2 as well? Since S2, S6 and even S8 have the same measure.
im thinking a threaded pill to replace the one that's in it BUT little longer as well ???
i measured my S+ with a optic/LED's and measured 21mm deep and be able to screw the body back on, i dont like the spacer idea because then it will be falling out and not good of contact ect......
If there isn’t a threaded driver retainer or grub screw for a ground wire then it’s nice to have copper or brass to get the driver grounded with solder.
Threaded pill is great. Hopefully it is not too difficult to make. Please provide more space for protected 18650.
im having a sample heatsink made so i can have anything changed before they are all made, only thing ill have to do or find out is how long the protected cells are that u guys might use ?
~6.95cm
